Mk3 Headlamp Washer System
Hi all, i know this part is extremely rare (but still available) i can't justify the brand new price.
Please let me know if you know of the headlamp washers etc available for the mk3.
  • Views 1.7k
to do it on a budget:
number 9, 10, 6,7 u have :-D
22, 24 are no longer available and not really needed, all the bits round the small pump u also have.
1,16,4,5 u need to buy :-(
8/11 hunt any old fat audis on ebay being broken and you should get it half vag prices 8-)
20 is just rubber pipe out B&Q, EKTA tells you what lenght to cut it to :thumbsup:
25 is optional or not really needed as it just is a rubber through the front bolt on panel. 23 is optional (use a cable tie)
21 is just jubilee clips u can buy anywhere.
i recon about £100
heres some pics of the views u dont usually see....
Edited by genesisGT
brilliant stuff Richard.
i have got rid of my rear wiper so i could plumb them up to the outlet for that on the pump?
good idea martin, but the headlamp washers have a serious drinking problem the 7.5L can go in under a week sometimes as they get addictive and soak everything about like up to 2 cars behind and anyone on the pavement! :lol:
but more importantly i think they need the pressure of the large pump to work as the bit in the middle of the bumper is a 1 way valve thats presure operated. u cant blow air down the pipes as i tried one day, and water it traped once it passes it.
also i only use just water in mine no additives etc as the stuff in it sits on the inner wings and will eat them. :paranoid:
more good stuff from you mate.
thanks for the info, this page is bookmarked!
