Rubber Door Seals On A Mk3
Theres a split in my door seal on my drivers side causing water to collect and rust slightly under the seal. I wanted to remove the seal, treat the area and put a new seal in. Is this easy to do? Any where would i get the new rubber from?
cheers
  • Views 1.2k
The seal is pretty universal stuff,most industrial supplies sell it and i should think most motor factors. A link would be good,Mikey.. Ah http://www.carbuildersolutions.co.uk
But id just get some from a newer and bigger door framed car in the breakers.
Trim both ends,and then it'll be good as new.
It's as easy as it looks, unscrew the tread plate that holds the carpet down, pull the seal up, slap some kurust down, touch up the paint and put it all back together.
If I'm replacing a door seal, I normally get one out of a scrap Volvo because they're the best ones going.
cheers guys
