Mk2 Fan Squeak..would This Work?
saw this link click here
its suggesting making a hole in the fan casing to get some oil on the bearing? any opinions on if it would work?
i was thinking maybe a slightly bigger so you can see where to oil then whack a vw grommet in there afterwards?
  • Replies 10
  • Views 2.1k
That looks as though it should work but a bit OTT.
Others on here have just sprayed wd40 in which keeps it quiet for a bit. A bit smelly though.
Depends how you want to go with yours
I've been misting a bit of grease/wd40 into the end thats open...it does shut it up for a while , i assumed there was another bearing where that drilled hole gets to?
is that so ? if not why bother drilling it
Maybe so then
Dont know anybody thats tried it, but it looks easier than dismantling the whole heater
All these pikey advises you're finding are due to people who cant be bothered to find out how easy it is to do something properly.
Nothing new there,then.
I've done it,bit vague to remember every detail but.. The whole heater unit simply unclips from where its sitting by sliding clips,top first,and once its away the two halves of the casing come apart as easily (two waterpipe circlips,a plug and a cable clip are the only other challenges stopping it). With the unit out,you can then unclip and slide off the fan drum,grease the spindle properly,and re-assemble.
i decided to strip the heater box out...as above its 10 mins work tops to whip it out the car
split the box open easily enough,i warmed the lugs so they wouldnt snap although i couldnt see a way to strip the motor /fan any further
managed to direct the pointy nozzle through the fan blades and with a screw driver held against the pipe i directed it at the bearing and gave it a good blast , seems to have done the trick for now at least
that link i posted at the top...not really worth the hassle as you wont get a direct blast and whatever you spray in there will coat the matrix and stink for 100 years , and you can take the box out and do a better job in around an hour
Edited by steveo3002
Don't know what you mean.
(pic)
Ex RAC,too..
That wrap next to your tow,looks like a hot air balloon!
oh well spoke too soon the squeal is back already
might try some other kind of spray grease
I did something similar sprayed carlube spray grease and penetrating oil in there through the fins of the fan.
It's lasted a year fine but on a particular cold day started squealing and went away the next milder day.
hmm maybe i should wait until it warms , it was especialy cold yesterday we got our first snow
