Weller Wheels
Hi there guys iv been on weller wheels site and found some nice 13s but the centre bore is wrong and they dnt do any with the exact bore for a polo any ideas where i can get some that will fit on my 6n ? cheers matt.
  • Replies 11
  • Views 1.4k
Size: 7.0 x 13Stud Spacing: 4 Stud x 108.00mm (4.25 inches)2nd Stud Spacing: 4 Stud x 100mmBack Depth: 100mmOffset: +3Centre Hole: 65.0mm will these fit ?
they will with spigot rings..
eBay spigot rings
you need 65 -> 57.1
Yeah spigot rings and you should be ok..
ET 3 so might juust be ok on the front, i'd use 165/55's though.
What u mean might just be okey m8 ? the et need to be abit more to clear calipes ? ? dnt want to buy the wheels and they dnt fit lol cheers for help :-D
He means they'll stick out like the wheels on a F1 car.
Et3 on an 8j's a bit low isn't it? Might have trouble keeping them under :?
There 7x13. I'd say you need an offset of at least around 15-20.
ET3 on 7j, that'd poke a bit.. on a mk3 anyway..
Most of the illegal Mini fitment ones are ET-7 so that extra 10mm isnt gona help much..
As Kam said, ET15-20 would be more ideal.
:lol: f1 car ay ! cheers for help guys :-D now to find some with et 15 - 20 lol didnt see any that are 4x100 and the rite et :x anyone else sell these ??
Even if you get higher offset ones you can always bring the offset back down with some spacers. But if they are to low an offset its a lot more tricky to make them tuck in more!
If you're buying new..
http://www.wellerwheels.co.uk/catalog/103-...ort-328330.html
ET25, you could easily drill a 4x100 PCD hole pattern into those..
Or track down some 7x13 Mattigs which, i think, fit on the front alot better and look just like Wellers..
