How Do I Change Front Wipers :s
had a search for ages but nothing....probably because its so simple. but I'm eager to fit my new aero wipers too the front.
thanks
chris
EDIT: And they are bosch wipers on there just normal wipers. I have read that i need to push a clip in and pull it but there is nothing to push or pull.
Edited by mcchriswood
  • Views 774
Lift the arm up, rotate the blade so the rubber is facing you, and push down :D Should just slide off, unless there are any extra fancy clips or anything.
thanks sorted it was a bit rusty so just stiff. sprayed a bit of wd40 down there. thanks can now be delted :)
