How To Take Off Rear Badge Polo 6n
hi jus want to know how to take off rear badge?
also hoe to reapply it?
also how to paint black?
  • Replies 8
  • Views 1.8k
Flat headed screwdriver to pop the badge out mind your paint work need to give it a pull ,
If the the black sticky stuff is still on will be ok to put back on with or dd tape
Pop the vw badge of the suround then sand it down plastic primer , black paint , then clear lacquer.
Edited by Po*Low*
GREAT HELP MATE
MANY thanks
GREAT HELP MATE
MANY thanks
No worrys mate
Don't use a screwdriver to take it off. Good chance you'd scratch the paint doing that. Get something like a bodge spreader as it is less likely to damage the paintwork. Or anything thin and plastic like maybe an old credit card or something.
better of using strong fishing line as it wont damage paintwork
warm it up 1st with heat gun and then get a plastic spreader under it. Job done......
so its the same as taking off the bump strips then??
need to do mine
yep- will do them as well. i agree dont use a screw driver, head up with a hair dryer for a few mins, then will peel off with your fingers.
Rag and a bit of petrol to get the glue off. tidy
