Write Up On The G40 (creation Of The Devil!)
Whilst looking for a suitable G40 for sale I have come across this write up! Just genius! :-D
Picture the scene. The VW design team are bored. Over paid, under worked and a head full of humour. One of the team breaks away from folding A4 paper into darts and launching them across the department, and picks up an old dusty design print of the polo.
“guys, what about modifying this?”……………….
The story begins………….
A once plain, boring, Saturday shopping car was then sent down to the depths of the VW plant. A rather red man with horns then signs the paperwork for this inoffensive little run around and the doors close behind him……….
Laughter can be heard bellowing loudly from his den. Clashing steel echoes throughout the building. Then, finally, the doors open to reveal the G40.
Based on the coupe is as far as it goes. The power plant is a 1287cc multi point fuel injected Supercharged one. Mated to a 5 speed gearbox. Small arch extensions are fitted to the body, front bumper is deeper, rear bumper too.
So just what is a supercharger?????
The easiest way to describe it is a mini compressor. I’m sure that most people have seen the devices that plug into the cigar lighter in the car and then produce enough compressed air to inflate the tyres. Well the principle behind the supercharger is the same. It’s mounted at the side of the engine and driven via a belt from the engine. Instead of a pipe to blow your tyres up though, there is a pipe to the induction side of the engine. The general idea is to “Force” as much air as possible into the cylinders to improve efficiency and of course power. Unlike a turbo the power is instant and smooth.
After Satan’s time with the G40 it produces some 112bhp, more than enough for the traffic light grand prix. Road holding is excellent through up rated springs and shock absorbers. Reliability is superb cause it’s a vw. However the brakes can be the only let down. Excessive pedal travel is a common complaint among G40 owners, but several people do brake kits for the G40.
As only 500 were imported into the U.K. then exclusivity is almost guaranteed. Insurance is respectable and economy is fantastic.
IF YOU CAN FIND ONE TRY ONE. YOU WONT BE DISSAPOINTED
Engines are 1272cc, and made 113bhp.
Bumpers are the same on all models of Mk3 Coupe.
Road holding is poor.
Other than that it kept me amused for 2min :)
lol
"The easiest way to describe it is a mini compressor. I’m sure that most people have seen the devices that plug into the cigar lighter in the car and then produce enough compressed air to inflate the tyres. Well the principle behind the supercharger is the same. It’s mounted at the side of the engine and driven via a belt from the engine. Instead of a pipe to blow your tyres up though, there is a pipe to the induction side of the engine. The general idea is to “Force” as much air as possible into the cylinders to improve efficiency and of course power. Unlike a turbo the power is instant and smooth.
After Satan’s time with the G40 it produces some 112bhp, more than enough for the traffic light grand prix."
that was a good laymans term description,
anyone want to explain turbos too me? :)
Pretty much the same, except the compressor is driven by the exhaust gases exiting the engine. Large turbo's tend to 'lag' meaning it takes a short amount of time for the exhaust gases to turn the compressor to a speed at which the air going into the cylinders is compressed enough to produce an increase in power.
Turbo's tend to rotate at many (often tens of) thousand RPM, superchargers usually rotate much slower, maybe 2 or 3 times engine RPM at a maximum, depending on the design of the supercharger and the pulley size.
Superchargers are more 'instant' in their power output, but use a percentage of the engines crank BHP to turn them. Turbo's use hardly any 'power', as they use waste gases, however they do often 'lag' behind, meaning you have to wait a second or two before you get that satisfying 'boost' of power. Both have their advantages and disadvantages. :)
thank you
