6n2 Gti Door Card Removal
I need to remove the door card on my polo gti because i need to fit new grab handles i took the grab handle cover off and un done the 2 big bolts and removed the small screw next to the tweater and was unsure wheater the door card just pulled off or there were plastic clips or something else holding the door card on. Any advice will be much apreciated Ryan.
Thanks..
  • Views 1.8k
yep, you dont have maunal windows so there wont be a screw behind there, so just the two at the grab handles then the rest of the card just unclips, get a flat head screw driver underneath at the bottom of the door car and prise off, might be quite stiff! :D
Thanks matey
theres also a small screw at the top of the door card near the tweeter
