Garage Clear Out
g40 conrods with bearing caps and bolts, all in excelent condition
20 quid?
used g40 clutch, loads of life left
10 pounds
polo washer bottle
5 pounds
expansion tank, some one painted it balck, easily removed
5 pounds
Brand new box from vw, mk3 polo alternator belt, purchased in error
5 pounds
G40 rocker cover, very good condition
15 pounds
g40 Charger oil feed lines
10 pounds
drainage hose groment mk3 scuttle pannel, excellent condition
3 pounds
mk3 gt brake vaccum hose
3 pounds
mk3 rear gearbox mount, bush bracket etc
8 pounds
g40 dizzy unknown condition, broken hall sender, see pic
3 pounds
speedo cable mk3
3 pounds
accel cable mk3
3 pounds
g40 feul pump
15 pounds
g40 boost hoses, large plastic one has been cut, easily fixed with a silicone hose
10 pounds each, 5 for the cut one
g40 engine loom, labeled up came with my conversion but i already had one.
40 quid
please let me know if i am off with my prices, i just guessed them
postage avaliable on all items, i would just have to work it out though
I'm located in north london, potters bar
thanks
jason
Edited by BLACK6N_POLO
  • Replies 13
  • Views 857
hi, would you separate the engine loom and the lighting loom. I'm after the lighting loom?
jack
jack
its just the engine loom that is for sale mate, its the wiring you need to swap if you were to do a g40 conversion
mate will you be willing to post the used g40 clutch, loads of life left
10 pounds
i dont supose you have the crank pistons and gudgeon pins to go with them con-rods do you mate?
p.m. me gaz
what sort of condition is the loom in? get giorgio to text me....I'm very interested...
dizzy, loom, gearbox mount, top right hose
mate sell me the clutch lol i can cellect on wednesday
bump
bumparooo
Hello, I'd have the g40 fuel pump off you if you've still got it. Pete
fuel pump sold
bump
what cond loom in
would you post the rocker cover if its still for sale
