Foglights For 6n2
Hi Guys,
I have a 6n2 polo.
I want to add foglights to the front and just need to know exactly which parts I need to purchase and where is the best place to purchase?
Also how difficult are they to fit?
Thanks.....
  • Views 877
Hi Guys,
I have a 6n2 polo.
Thanks.....
i should be doing this in the new year.
ebay or breakers for parts...
if you want them not wired up, thats it, should be easy to fit, wiring shouldnt be to difficult though, and I'm told you need a new switch for them inside, it pulls out kinda...
let me know how it goes
You will need the actual foglights, new lights switch with front fogs on, and foglight grills, and two h7 bulbs to put in the foglights.
Fitting is easy,
1. Undo the original grills which have 1 screw each holding them on to the bumper,
2. Take off bumper,
3. Using self tapping screws (or small bolts) attach foglights, attachment points are already predrilled.
4. Fit bulbs,
5. Plug in the wiring (foglight wiring is standard on all 6n2s).
6. Refit bumper.
7. Change switch, remove by pushing the switch in turning then pulling out. plug in new switch, and hey presto all done.
I bought everything from ebay from a seller called lesbray, otherwise scrappys or dealers for parts.
hope this answers your question
EDIT] there is a foglight installation guide on uk-polos.net, its worth a search on there if you are not sure.
Edited by hammy88
