My 6n2 Conversion!
so nice update. head rebuilt.. had it out 4 a drive.. and it not gone bang yet :D......
started sanding down car.. ready 4 spraying only to find out i had ran out of satin black... FAIL!!!!!!lol
had a lil wiring hikup on the 6n2 rear liights.. drivers side.. was completly wrong.. so inverted the cables and it all worked.. (pass had the indicator and brake light wrong to so swoped them over..) and all works perfect now..:D
so here are the pics..
oh and now lets play SPOT THE DIFFERANCE :D
PIC1
PIC2
:D
hope you all like...
  • Replies 62
  • Views 21.6k
looks good, have you onyl sprayed the small area under the lights black ??
ermmm kinda :ninja:
so the polo is broken again!!!! :crybaby: so while i wait to work out how to fix it... i thought i would start on changing the colour!!!
this is how it was left today!!!!
and i thought i would see how it looked with out the wiper... what you think??
hope you like it...
Looks good but if youve gone to that effort i think it'll need a respray :thumbsup:
lol once i have the funds then yer lol....
Quick Q, did you need to modify anything on the 6n2 boot because i seem to remember Mike on Uk-P said he had to do some work to make it fit flush?
yer .. mike had same... but i wasnt convised so i loosened off the hinges.. pushed them up as much as i could... and then nipped them up... and seams to sit allmost perfect.. (part from od small gaps caused be a shaidy past.. :()
but tbh a bit of light filler work will soon bring it into line...
i will sort out some pics.. 4 a thred...
bloody hell what are you doing with that poor car!
^^ :? please tell me you keyed up the original paint before you painted it? It just looks like you havnt...?! Hopefullly it will look good when its all sprayed up though :thumbsup:
So if i was to get a mint one? Because tbh it beats smoothing my 6n one :badgrin:
once fittted properly with 6n2 rear lights there is a bit of a ledge between the lights and resess be low. and the bottom line of the boot should line up if it dont keep trying to "lift" the boot lid when the boot is shut the roof and lid should also line up perfectly..
i do have pics but not on this pc...
McTangus:
yes i sanded it down with wet need dry 1st...
tbh.. i should hav got the heat gun out and wall paper scraper out like i did 4 the roof as the laqure is just falking off the poor girl!!!
once i have finished the front am gona give it to my mate to respray... thats if i can stop the engine from breaking all the time..
Edited by mk1poloblade
alright guys i had the same problem with the 6n2 tailgate and lights and tbh you do need to weld a plate in place and fill it to bring it out the 5mm that it needs. pix of mine below.
this is how flush the lights and tailgate looked after i had welded the plate in and filled it
here is both sides done
after paint
just think it finishes it off and gives it more of a (out the factory) kind of look
much better smoothed filled and flushed with body and lights imo.
cheers mike.. does your boot sit flush with the roof???
i love your polo so much....
really know how u did your bummper.... as mine looks pooo compared :( lol
cheers mate yours is coming along nicely too pal defo go for a respray when you get some wonga aka cash.
yeah mate the boot lid sits perfect to the roof.
my bumper number plate light has been done with fibreglass and filler mate only took me 2 days to do thought it would take me longer as it was a pain in the ass to get the shape right ended up useing tin foil to mould it.
Edited by mk4mike1.4
lol... i just got the dremal out!!! as i needed the bumper back on!!! the fuzz round hear will try you 4 anything!!! lol... (thats wen they are acctually around tho lol)
gess al have to take it off and give it a full go! :(
was gona go side exit as i found a nice can to do it but i need cat back so i getting peteg40 old back box.. so it gona be a nice in you are face upsweep lol.. but sould compliment it nicely..
Looking good mate - will check it out next week
u in thurs evening to pick up bumper??
yep..got no plans :retard: lol
oh that reminded me what i did to it 2 day lmao....
put a new magnetic sump plug in mine looked a lil FCUK'ed.. and fixed the leak from the sump.. some of the sump bolts had worked loose :(
and still trying to fix the rocker cover retining things.. as the thread went again :(
so time for the BIG update!!!!!! 8-)
so thanks to jay t 08 i know have my 6n2 front end!
parts i got:
6n2 front pannel: does need trimming down to fit!!!
6n2 slam pannel: not used did not fit!.... slightly chopper down 6n 1 to fit!! i think its a stronger fit!!!!!
rad+ fan... can use the 6n rad.. they the same!!
headlights!!! tricky bit needed big rewire to work on 6n lighting loom
wings
bumper
grills ect
it littered my garage floor quiet well i thought lol
so gave it all a rub down.... and a coat of satin and litterally bolted it all on!!! was harder than i 1st thought as its not all direct fit! in fact only the wings and the hinges for the bonnet were! lol but oh well!
so here is some pics i took during the build.. (only just finished the headlights 20 min ago.. all tested and fitted lol)
and here is a test fit befor i sprayed up the bonnet and bumper!
and here is the pic head lights in and painted!! :p
hope y'all like it i wish i could be outside still working on it! lol....
OMG its a 6n2 how cool is that!!! I think i would flush the boot personally like mike has to go with the smooth flow! Looks mint mate keep up the hard work!
lovin this such good work amazing effort buddy keep it up bud :)
Just read through the build thread, impressed with what you have done so far! Keep it up :thumbsup:
Looks good mate
Shoulda used it myself lol
Jack
cheers i wont to keep it as close to standard as possible
yer now its on i have a lot of little bits to fettle so it all fits properly...
not happy with the headlights atm.. when funds allow will put black halos to fit with the look of the car!
Looks good mate
Jack
lol was harder than thought as the front pannel didnt fit properly and the slam panel was sort... so am gona cut the 6n1 down to fit better!
so for you all to see
so there you go hope you all like it!! i do :p
