Mk2/3 Remus Ss Exhaust With Lifetime Warranty
Used for 1500 Miles before replacing with a full custom stainless system with no silencer for more noise. This Remus system has a very very subtle noise on idle and makes a nice noise at high revs without being intruisive in the cabin. I wanted loud noise in the cabin hence replacing with a straight thru system
Stainless Steel Remus Single Round 3.5" Tailpipe & Backbox
Reducer
Coupe S Centre Section in VGC and Flexi (To Downpipe)
85 Pounds.
Can take to the rolling road day otherwise collection from central manchester.
thanks
Saf
Note these pictures are it as new, i will take up to date pics tomorrow =]
Ta
  • Replies 21
  • Views 522
Reckon this would suit my 1.6 saf? Would you say its more free flow then a G40 box?
do you think this will fit on my polo g40 ?
what car engine did you fit this to ?
can you not post this ?
Definately more flow than a G40 box, id pretty sure the main pipe is 2 1/4 inch bore, which is beasty =] I'm pretty sure g40s are 1 3/4 inch.
I definately will suit the mk3 more, i had it fitted to a mk2 polo and it didnt sit high enough, looked fine on the mk1 polo however. I think its just due to the lack of big bumpers that made it not look right.
It will fit a G40 and Carver probably your 1.6 without the need for a reducer dependant on the size of current mix box
and i really would prefer not to post but can do if really required. 20 quid for courier + whatever for materials to cover it safely
does it come with the bracket to hang it on???? only asking as i cant see one in the pic
Yes it does, Its not shown in the picture as it wasnt fitted on at that time, its a wrap round hanger which holds together with a 13mm nut and bolt
sounds the tits this does.. heard it at a meet.
Arrrgh I'm so tempted to take this home at the RR day!!
is it a full system that connects from the downpipe Saf. (Pretty clueless with these things)
Also would i be able to get it to sit right through different rubbers in order to make it to tuck to the bumper?
Yeh man just connects up to your exisiting downpipe, its a full system back from there, although the centre section isnt stainless, the backbox and connecting pipe is stainless however and painted black.
You could use different rubbers to make it sit higher, or get someone to tack weld two other hangers and use those instead of the wrap around bracket. I think it would sit different to the Mk2 on a Mk3 as the Mk3 has a larger deeper rear bumper
should have rubbers and clamps with the exhaust.
New pictures will be up on friday as my photofuckit allowance has expired till then =]
danke
Awsome, may take this off you at the RR day Saf. Will see wht the financial situation is like!
its not 63mm by chance is it Saf me ole China?
aye should be as 63mm is 2 1/2 inches which I'm almost certain is the bore, I'm just about to stick a pizza in and ill clean up the exhaust and take some piccies.
I think you can still see pics with a link straight to the photobucket
http://s16.photobucket.com/albums/b12/yousafn/
anyway gimme 15-20
its actually 51mm - a 2 inch bore, and the reducer thats been welded onto the SS system is about 45 inches for the Coupe S system, which is 1 3/4 inch bore.
Someone has already said they will definatly take it at the RR day so they have first refusal on the day, thats Oily Fingers.
Although as I'm a bit brass, and i get paid on the 28th i wouldnt mind selling it cash in hand or by however means before the RR day, postage isnt an issue, collection is preffered or i can deliver depandant on location for petrol costs
Saf
Damn. If it was 63mm, I wouldve poopal'd the money (plus charges) today.
Hope you get it sold quick matey.
cheers mucker and no worries, see you at the rr day fella
bumpage
I'm still up for having this from th RR day is no one else gets it from now till the rr day
any pictures on car?
tell you what oily mate its a done deal, as i start my new job monday its easier for me just to bring it to the rr day
drop me a pm friday to remind me to pack it in the car =]
cheers
saf
ohhh shweet, its done then. I'll pm u friday with my mob number and remind u. Cheers dude!!!
