Water In Footwell
hi I've got water coming in to the car i think its coming in bottom corner of my doors, door seals look ok is it just a case of getting some new ones and where from any suggestions appreciated cheers josh
  • Replies 10
  • Views 1.4k
had same thing on sister in laws p reg polo last week the drain holes under the wiper mech were blocked hovered all the gung out now its all sorted
Can measure your seals & get some off a Volvo @ the scrappy. They are aparently the best ones
check the plastic membranes behind the door card first...they often slipt and allow water in
this sounds stupid but do door seals just unclip or something :lol:
Will just pull off once youve removed the trim plate on the sill. Usually a joint there
what car is it for a start? if its a mk2 or 3, then be very afraid as water in the footwell will be one of three things
1. sunroof drains blocked (easy fix)
2. water leaking through windscreen due to corrosion under the seal (very difficult fix)
3. battery tray rot (can be easy if not far gone, but an absolute nightmare if its totally shot)
dont have a sun roof , battery tray is fine , there is a tiny bit of corrosion under ther window not big enough to let much water in though
believe me, it only needs a tiny hole to fill your car with water. lift the seal back and you will probably find its worse than it looks.
I have this problem too on my mk2. It is definitely none of the 3 mentioned options as I can see where the water streams in from the door. It's a pain so I guess I will be getting new seals soon as well.
likewisee
water in the footwell behind the driver seat :( on a mk2
non sunroof
