Can U Get P80 Wet And Dry?
anyone the lowest i can find which is in halfrauds is p120
  • Replies 9
  • Views 1.5k
whats it for ?
cant say I've seen it , again whats it for
any reason you cant do it dry to begin with
my halfords sells P80 grade!
you dont need water for basic filler removal usin 80 grade paper anyways. but its not called wet & dry paper, its called summat different in halfords and the sheets are white.
you shouldnt really use wet & dry for bare filler anyways ! just use a dry 80 grit then gradualy move to a smoother grade untill its to a standard ready for priming. . . then once its primed use the wet & dry, either 120 or 180 followed by a smoother grade.
go to a paint shop like colour tone or autopaint they will have it all and cheaper
DO NOT sand bare filler with water as it will absorb it and take a LONG time to dry out, causing possible future paint reactions and the like, sand it with 80, then 120, then 240 and prime a few times with a hig build and then start your wet sanding
its for polishing a rocker cover#
i can get p60 they do p80 aswell
matt
