Removing Gearknob - 6n2
How the fuck do you remove the gearknob to replace it? :lol:
Cant seem to get it off at all by twisting it like in a normal car :(.
Any advice is appreciated :D.
Cheers,
Dave.
  • Views 958
Cheers,
Dave.
If I remember correctly you will have to lift up the gator and there is a metal clip underneath holding the knob on.
if its the same as a mk4 then lift the gator up and there is a stupid vw clip under there which need to be eased off or cut off then it will slide off the top
