Sorting + Preventing Rust
Rear arches, aswell as the middle of the skirts theres abit of an obvious weak point which has started to rust
I don't know if I'm getting paranoid but I'm noticing it more and more and its looking worse..
Any advice to get rid + stop it coming back? :D
  • Views 914
Depends if its just light surface rust or the really scabby flakey stuff as to how long it will stay away
Wire brush it back to bare metal 1 inch into good paint. Can use a drill bit one or if its bad a grinder
Paint metal with Kurust or similar. Follow the instructions
Use a zinc based primer next
Top coat time. If doing under the sill then i just underseal
Depending on how bad it is/how good a job you do, it may come back after a while, but hopefully not for a few years
cheers for the help there, I'm as paranoid as this person lol
can anyone tell me how you do the lip of the arches tho...i wanna get them rolled but am worried about the little bit of surface rust
Cheers for info...Ill get a picture up of the rust on mine, its literally just the lip of the rear arches like
