Bit Of A Winter Time Warning To All...
Well i went out today to do some work on the mk1 caddy today, went out fired it up and smoke poured from what looked like the water pump.
After looking i could see the water pump pulley was seized on, and the smoke was the alternator belt wearing around it!
so i stopped it and checked the system, completely frozen solid with ice
Now yes I'm completely aware of the stupidity of running water, but the only reason that is, is because the coolant system is not complete, I'm still waiting to sort a few problems with it, as that was todays task!
So i got thinking, hell imagine if this was on the mk3? on the caddy the water pump is part of the alternator belt set up, but on a mk3 the water pump is on the cam belt, so if this happend on a mk3, it would seize, and pistons would hit valves!
So really its a warning to anyone who may be running water, or part water, check your system isnt frozen, as if you dont it could cost you a new engine!
  • Replies 28
  • Views 2.4k
was thinking this before i started mine this morning so took a few precautions,,,gonna top my coolant level up now..
First thing i did with my MK3 when i bought it in November, was caught out with a Honda Civic 16V i bought around the same time of year a few years ago, froze solid on boxing day, managed to defrost it with a heat gun, was very lucky though, started and ran as if nothing had happened.
Good point about the water pump though, would definetely strip the timing belt and result in desaster, luckily i'd checked that Honda before i started it.
Edited by MarkGenesis
Mines half water half anti freeze. I'll have to check it before I go home later!
its normally just when its water, the coolant dilutes it i do believe?
but i have to say this winter is proving to be quite a bad one, it was -5 a few days ago, i cant remember it ever being this bad?
I feel for the people on the south coast. -12 the other day and the sea froze!
It must be the much vaunted global warming yje ecomentalists harp on about.
anyones washer jets freeze
mine are heated :D
but noticed as you spray it on to the windscreen, with a pretty high concentration it still freeze's
coolant mixtures is sumat you def need to look at this time of year
50/50 coolant mix
Washers are a 100% washer fluid, good until -15c, did have a 50/50 mix but the water would freeze on impact with the window.
I have no idea what's in mine, and I need to use the car later on today. :?
When I was travelling down from Scotland the other week my washer jets froze pretty much instantly on my screen, resulting in me not being able to see a bloody thing through the sheet of ice. Which reminds me I need some anti-freeze!
Yes,its possible - i did it on an '84 Cavalier GLS in the mid 90s. Turned key,it fired,stalled abruptly,then would do nothing but click. Turned out i stripped a foot of cambelt teeth and punched the head. A popped core plug was the first clue when i peered into the bay. Id only had the car a few days.
Problem for anyone with a frozen cooling system now is that it may not thaw for several days. And whilst it may all look liquid,there could still be lumps of ice in there - and they'll smash your plastic water pump impeller on contact.
mine are heated :D
Saw a bloke last night trying to use wipers to get ice of his window when it was -8. He was spraying water onto the windscreen to try and and move the ice off :biggrin:
Worst thing about it was he was driving along really slow with the hazards on and trying to defrost on the move...some people.
nearly got flattened at work by a guy in a peugeot who was hanging out the side window because all the rest were iced over!
how they think they're being sensible i'll never know.
from august up til the beginning of November i was running just water as i totally forgot to get new coolant when i fitted my new thermostat/housing. glad i remembered to get some coolant, got a nice clean header tank too!
Check your cor plugs are all intact and hope the block isnt cracked!
what are core plugs ?
heated washer jets are a false sense of security, the jets may be heated, but the 3 or 4 meters of feedpipe freeze lol
is it safe to use anti freeze in your washer system?
Some washer fluid will stop it freezing. Have a look at the bottle.
Screenwash contains antifreeze. The winter stuff does,anyway.
And yeah Dan,if you have no leaks when it thaws then you'll have been very lucky tbh. I've still got snow around my drive - unless you can park in a heated garage you're not likely to find out for a while yet.
They are bungs in the casting of the block where the cores for the coolant gallerys were during manufacture.
so if i put some coolent antifreeze in my system it wont deteriorate my washer pipes etc
You wouldn't catch me putting anti freeze in my water bottle, it's seriously toxic shit. I'm no expert mind maybe in a large dilution but it can't be good for the environment or your health.
According to Practical Classics they recommend Decosel Excel for screenwash, this was a year back. Think it's pretty common in most motor factors.
Oh and cheers for the warning although it's above freezing where I am. My washer bottle did freeze a month back though.
Should be about 2/3 antifreeze 1/3 water for a coolant winter mix iirc. The screenwash is not antifreeze like engine coolant; don't be tempted to put that in your washer tank. Neat stuff will strip paint like brake fluid if left on long enough! Isopropanol is the alcohol agent in the screenwash to help de-icing.
my mondeo is struggling in the cold it really doesn't like to satrt think il be checking the polo tommotow though! :thumbsup:
