Good Or Bad Idea?
I want to spray the badge on the back of my car. It's a Polo 6N.
I plan on spraying it dark blue and the VW outline will be black.
What do you think?
All opinions welcome
  • Replies 35
  • Views 2.8k
go for it mate....pop it off and paint it!!!
worth a go... at the end of the day, if you fuck it up or dont like it then you could pick up a badge for about a fiver.. if that.
That's what I like to see, a bit of positive attitude towards the unusual.
Think I'll go ahead with it then.
i take it your cars blue? Nice to see something different than the usual black badges. Get a pic up when its done.
Yeah go for it mate, just make sure u paint it somewhere warmish with all the cold weather we've been having. Making sure its well ventilated obviously lol.
here's mine....
Go for it whats the worst that can happen its just a badge at the end of the day and can be fixed quick and easy!!!
I just don't want it to look chav-ish.
My Polo's black actually but I'm theme-ing it blue and black. The speakers inside are blue so it's kind of colour coded.
My front badge it black now but I want to spray the grill black fading to blue.
I'll put the pics up when its done.
@McTangus: I initially got the idea when I looked at your car. Sorry for the unoriginality.
dude shit loads of people have done it!!! Go for it!!
That's pretty cool lookin METROMON.
Has anyone got any tips on separating the VW symbol from the background when spraying?
Yeah go for it!
I have sprayed my front one black after deciding to keep the badged grill, just need to do the back one, are they easy enough to get off? cant say I've tried yet!
you can get the rear badges off the same as debadging and de-bump stripping your car.
my way - heat gun and credit card :-D
Yeah go for it!
seanvw and lots of others say that you can just use a heat gun, use boiling water, or a hair dryer but I literally pulled mine off by hand.
I just grabbed it and twisted. :-)
Don't know what to put it back on with though?? :?
Edited by Jaych1000
Yeah i agree with you.... i used a hair dryer and then pulled the bump strips off my car... left loads of black shite on the site of the car tho, took ages to get off!
the backing just pulls off the badge, there stuck together with two little pin bits so reattach them with glue or something
but i didnt keep the backing on mine, jsut filed off the little pins then stuck it back on the car with clear silocon
like the white background. one of them little touchs you probably wouldnt notice but make for a good overall effect.
Shame mine is forest green... you really wouldnt notice me painting the black backgroud green!
There's kinda spongey rubber padding on the back of the badge. I plan on using the silicone glue to stick the spongey part to the back.
I have black silicone glue that you would use to put brows onto the car but it has acetate acid in it. Don't want to risk damaging the paint.
This is what I have planned for this weekend, just nicked some sticky foam pads from work to stick it back on
Hmm I may try at the weekend then! Did think about getting rid of the bump strips too but dont want to have to drive around with loads of glue or whatever it is if its hard to get off!
get a mk3 golf highline badge for it (if they fit)
looks smart!
youll get the glue off a piece off piss with a filler card and some thinners mate. only thing is if the previous owner has painted a door or rear quarter then its gunna be a different colour or colour match underneath ha. one of them things init.
Well a bit of advice, the spraying isn't too hard to do. Putting masking tape in between all the cracks of the VW symbol was time consuming and tedious.
Maybe I was just a bit anal about it.
I just sprayed the last colour onto it and now I'm just hoping that when I lift the masking tape, the colours turn out right.
Will keep yous updated.
:D
read a guide on it on here once, showed how to separate the badge from the black backing to spray seperately
also in the guide they went to teh dub dealer and got a black badge backing from a sharan which is slightly smaller than the one on the polo and they used it, looked a lot fresher.
I think I just read that.
Ok so I need a bit of advise.
After reading a similar thread, I noticed that they were talking about removing the VW from the round rubber bit.
I took both parts off the car!
Is that bad?
Should I separate the vw plastic part from the circular rubber pad??
