Good Or Bad Idea?
mate both can be detached and fixed back on very easilly with the help from glue and double side tape! It all depends on what colour you want the back plate and what colour you want the badge. I personaly only removed the badge, then masked up and sprayed the plate (on the car)....then i sprayed the badge and re-fitted it! SIMPLE
  • Replies 35
  • Views 2.8k
Ok well first of all, thanks to everyone who gave me the advice that I DESPERATELY needed to do this.
Here are the pics as promised:
This is before I realised you can detach the VW from the rubber/plastic backing:
This is after I found out and separated it. For people who don't understand how to separate it or didn't know it could be separated, here's a few tips:
This VW plastic symbol can be detached from the background plastic piece and the rubber around the background can also be removed(but I think it's best that you don't).
The VW part:
The background:
Rubber piece and background together:
The back:
The finished product:
Can I just use super glue to stick the foam rubber to the back of the car??
This is just to help anyone who might want to search how to do this as I noticed a lot of people plan on it.
removal rear badge remove removing take off separate paint painting spray spraying.
Hope you like! :D
id use evostick mate you can get it from homebase cheap i used to put the lens back on my front indicator when the silly tit next door reversed into it on xmas day!
and as for the black shit left behind when you pull the bump strips off on my old fiesta iused a bit of lighter fluid on a cloth and slowly rubbed it off with no damage to the paint.
either that use autoglym tar and glue remover stuff stinks and foams a bit but shit hot mate good stuff to use. just give it a t-cut after and all will be well.
good luck mate hope this helps
Thanks mate.
I'll pop over to Homebase later today.
Thanks mate.
Looking good matey, looking forward to seeing a few pictures of it on the car
So I stuck it on the car with some Evostick and took a few pics. It's very... eh... apparent but I'll let yous decide how it looks.
Here it is: Picture132.jpg
any chance of a better picture taken in day light???
Yeah I'll get one tomorrow for you.
Legend
Here are the pics that you asked for(sorry for taking my time):
