Removing 6n2 Door Cards
Hi ALL,
I've been trying to take my door cards off so i can try and fit my new remote central locking.
The only thing i am struggling with is taking the window winders off.
Help would be much appreciated.
Thanks...
  • Views 974
yeah i am having the same problem 6n any help would be great
i am sure to remove them you need to get a flat screwdriver and with the arm pointing away from you push the disc behind where the winder pivots towards the end of the handle. its like a circlip and then the handle will pull forward and off the door card
yeah thats right Chrispy, exactly how i take my door cards off mate, the window winder has a casing around it, just needs poppig off then you will see a hole where a screw is present
