Help Please!
basically my drivers side door wont open, the key was stuck in it but i managed to get it out. the locks have alwasy been dodgy since i bought it, hence why the boot wont open either. But that might be because of the central locking. you can put the key in the driver side door but it wont open, how do i open my door?!
regards
steve
  • Views 960
mine stiffened up before, jab a can of WD40 on the keyhole with the red straw they give you, leave to settle for a couple of mins, try again. You may need a new barrel in the lock if this doesnt help
thanks buddy, ill try that, but i think it has actually disconnected from the lock. How do i open it then?
is yours a 6n like in the pic , if so
the paddle has broken off i reckon , will have to get in the passenger side and pull the knob up until you get it sorted , i replied to someone else in the body work section about replacing the paddle earlier jellos thread
Edited by polo d
can you take the doorcard off when the door is shut?
No, you need the get all around including the piece that meets the dash board.
