Mk3 Subframes
hi
just wondering how easy it is to swap a subframe from one Mk3 Golf seat to another ??
Matt
  • Views 702
not to bad mate , take the winder off and covers ( be gentle as can brake ) , them their is a clip either side and the tilting catches and the top will come off from the base
if you are changing the metal only , turn the base over and unbend the spike that hold then cover on , their maybe some pastic clips as well , if its a gti seat their might also be some wire holding the bolsters in place if so unclip also and then the cover should come off .
just make sure that the bases are the same , as the mountings for the seat back clips maybe further forward/back
done loads in my time should take about an hour 8-)
