6n2 Door Lock Mechanism - Assembly Instructions?
So the door lock mechanism on my Polo (2000 W reg 6n2 5 door 1.4se) dissintigrated...
The handle and barrel are intact, as is the electronic bit, the assembly that makes up the springloaded paddle bit is in pieces.
Bought some new bits but can't figure out how it all goes back togetherproperly...how does the spring return the key to vertical position?
Any ideas?
Might remove the passenger side and reverse engineer but don't want to end up with twice as many bits and no clue!
Ta;)
  • Views 1.2k
hi you fellow polo man
their quite simple , the spring goes in first and the little lugs on it go either side of the tab , loading it up then put the paddle in the middle of the spring , it will locate on shaft , you willneed to hold the barrel in from the front , then push paddle down and slide the clip on :thumbsup: this can be quite fiddely as the spring can jump about . check its all working properly before you put it back in the door ;)
Cheers,
I will give it a bash, see what occurs!
