Airbag Removal
Have a baby coming soon so was looking at removing/disabling the passenger side front airbag so a car seat can be fitted...
Has anyone done this themselves or paid a company to do it?
Any info would be great!
  • Replies 12
  • Views 2.1k
hi you mate , if you disconnect the air bag the light will come on and will fail mot`s , and to reconnect it you would have to reset the air bag modual aswell , unless their is a switch on your can have a look in the manual ?
can it be done professionally then anyone? I remember my Dad was quoted about £60 in his old Mk3 Golf VR6, this was about 6/7 years ago though!
The air bag warning light is not a fail for the MOT.
yep its def not a fail for mot, i went through mine with it on as i had a momo wheel on.
ttt
I'm sorry lads it definatly is a fail , you must have lucky tests , if the air bag is still their/seems to be it has to work , the car system checks , it should go out in 3-5 sec`s . so fitting a momo it will pass as their is no air bag .
unless they changed the law since i was MOTing to a lesser standard ?
was thinking the only way round this is to find a car with one air bag and fit the air bag modual , disconnect the passenger one , and the drivers will work as normal , the light will not come on , and you can swap between moduals and plug other air bag back in
They must have changed it then as the the airbags are not checked as part of the MOT. The most you will get for an airbag warning light is an advisory. If you have an ABS warning light how ever the car will fail.
no sorry saftey features on cars need to work other wise when you crashed a car no one would need an air bag and i have sold loads of them and the moduals from the breakers yard i used to work in , after the mot station
you must have poor testers , as if they advise it means they tested it = it dont work = fail
if your lights dont work they fail them !
I don't know what else to say but they don't test the airbag. All they do is that they see the light is lit and note it on the advisory sheet. I agree with you that it should be working but is just isn't covered in the current MOT.
If you have a quick google for 'Airbag warning light + MOT' it will bring up a few posts saying the same things.
The advisarys can contain anything they want them to contain. On my last MOT for my polo one advisory was 'No rear Seats'! Now I wondered what was suppose to be back there! :) Now if I had kept the belts in then it would have failed the MOT. Why I not sure but it would have.
The MOT is a very strange thing and doesn't always contain things you think it should.
max crox I'm sorry
i`ve just been away reading and you are correct its not a fail
now I'm going to rant about vosa , i cant believe that the mot people have done this it stupid . the whole point if an mot is to make sure the car is safe , and in my eyes it should be a fail as it used to be , whats the point of having life saving systems on a car if they dont have to work , its a no brainer . whats next , you dont need seat belts that work . its totaly dumb . grrr the stupid powers that be make changing the laws that save lives , go on everyone take you air bags off nobody cares if you die , grrr :angry:
Yes quite,
Back on topic, I've been reading the 6n2 manual, and you can have the passenger airbag deactivated for a baby seat. I would direct your enquires to VW to do this safely.
PoloD.
Hi I will probs contact VW to do this properly then, god knows how much it will cost!
