6n2 Gti Electrics....
Getting rather pissed off now. Is it just my car or are all Polo GTI's wriggled with electric faults? Just this winter alone
Passenger window motor and regulator failed.
Horn does not work anymore.
Both my tail lights blew and one of my back fog lights
Remote locking sometimes does not work.
Inside lock button locks car but then when you try to unlock the door won't open and has to be opened from the outside.
Anyone else like this lol?
  • Replies 21
  • Views 1.9k
Mine isnt bad *touches wood* but i have heard the electrics can be a bugger sometimes :(
mine allways pops rear brake bulbs but i think thats got something to do with the silly hard suspension lol
yeah, mines working fine :)
*touch wood*
Iv had a few problems with mine, quite alot of the lights have blown and the break light in the spoiler has now gone :angry:
I'm also having the abs light, and bootl light coming up on the dash for no reason, they keep going on n off!
mine sometimes does that thing u mentioned when u lock the car using those buttons, but when you unlock it, you have to open it from the outside.
only happens every so often tho.
oh and my rear windscreen washer thing doesnt want to work anymore!
my abs light is on, but I'm not sure if its just the connection has been nudged by mistake when fitting coilovers.
Yeah this sounds like a prety common problem... my back windowscreen washer dont work either!
I had similar to this, turned out had a broken wire in the rubber flexi-boot between the door and the body along with a blown fuse on the central locking circuit
i've had quite a few probs - i think its the 6n2s in general with the electrical probs.
the black/white wire in the rubber flexi-boot between door and body fixed my window and central locking problems as this was cut clean in two.
brown wire in there was frayed (earth??)
mainly window switches, fuses and wires so far so nothing major touch wood.
as far as those boot lights on - make sure there's no water running down from your rear wiper connection into the components as this can trigger the light.
your water pipe could be disconnected? this was what was wrong with mine. it's pretty common i do believe!
good luck with the car fella! at least it's mechanically sound....!
Sorry to go lil off topic, gtcoupe, you still after some switches?
My washer pipe went on the rear as well, but there's only two hex bolts to take off so you can easily do it yourself
yeah you didn't reply to me!! :shock: only keeping you going!
I got the problem sorted out thanks, but out of interest how much you after? cos i'm doing a bit of sprucing up atm!
my washer pipe is disconnected somewhere about the c pillar and i've all the trim off and still can't get at it :cry:
Take the boot lid trim off as that's where mine actually came off the connection to the washer jet
Sorry about not replying, been rather busy lately, you in NI? Say £40 delivered?
i had the trim off too but it's def in behind the c pillar as this is where the waters coming from.
you're ok. I know the feeling. work. eat. sleep. story of my life. hmm i bought a new drivers switch from vw themselves already, does the same one work in the passengers side? you don't have the whole block for sale too that the buttons sit in?!
Yeah same one works in the other side, only got the switches am afraid, haven't got the plastic surrounds
25 quid?
For all 3? £35 all in and posted?
i don't really overly need these! they'd just be spares....
30?
Sorted, that'll do me, PM me your address, you ok to pay over paypal?
My electrics have gone aswell (not a GTi though)
Both headlights, passengers window, wiring on the amp and my central locking alarm keeps going off on its own :crybaby:
my washer was working when i bought it... does the pipe just fall off??
also my boot light doesnt work, but iv had the bulb out and it seems fine, any suggestions?
That reminds me my boot light doesn't work either!
In my last year of ownership my GTI has been better than ever, absolutely fault free with the odd tiny niggle like every other car
