Blown Horn And Headlight Washers
Hi All,
New to the forum, I have a polo 6n2 GTI and the horn and the headlight washers have suddenly stopped working after this cold snap. The MOT is coming up in a month or so and I can't seem to find the problem any clues? Has anyone else out there had a similar problem?
Answers on a postcard.....
Cheers Very Much
Chris
  • Views 904
check the fuses first buddy then i guess follow it back through the wiring and check the switches, haynes will be a good help
Thanks mate, Fuses done already, wiring not so easy, i don't have a haynes for this and there doesn't seem to be one avaliable. Does anyone know if they are on the same earth or something similar its really stumping me (and annoying me!) I can hear the relays going but nothing els???
Chris
bttt
the fuse went on mine and i had the same problem
the fuse box is on the dash board when you opent he door
stick you key in the little hole there and twist and you will be able to see it i think it was a yellow one so a 15 or 20 amp
x
