Need Advice
before i venture into the unknown, i'm just looking for a bit of information as to the best way of removing the plastic door trims on a MK2F breadvan.
(the black bits going along the door, as well as the bit on the rear wing.
are they pinned into the body?
anybody done this before and fancies passing on the wisdom? :-p
cheers :-)
  • Views 823
alright mate , the strips are stuck on , so you can just pull them off and then you will have to clean the sticky stuff off , not sure of the best way to remove it , the upright bits are clipped in and have holes behind them .
door strips will be held on with adhesive as said ^^^^^^^^^^^^ so a kettle of water over them first to soften the glue and peel them off slowly to avoid pulling paint, then clean the excess glue off the surface and polish. Best thing is a fudge wheel which are available off of ebay or through frost.co.uk
the arch spat is held in with 2 clips and will leave holes which need to be welded and filled or leave the spats
ah cheers guys, that's a job for the weekend then lol.
