Not Sure
I'm after alloys for my dragon green polo just dont know wahts going to suit it? anyone got any suggestion?
also on lowering aswell... going to get some phil j coilys but not sure about the perfect stance( dont want it rubbing or anything)
thanks
will
  • Views 1.3k
http://www.imagewheels.co.uk/
there you go....
perfect wheels for ANY polo
some mirror polished ats cups 15"x7j
stretch some rubber on and you're good to go :thumbsup::nod:
there you go....
there's some very tidy wheels on there :p
thanks for you replys.. what hights would you suggest tot have the coilies at? dont want it stupidly low.. jsut a nice stance and so the alloys fit the arches nice?
it depends on the size of the wheels and tyres that you run! As well as the offset. But for a 15'' rim the standard is about 60-80mm down.....14'' would be up to 100mm and 13'' you gotta go even lower! BUT this is all depending on the offsets of your wheels....obviously if you have lots of poke your going to need rolled/flared arches and some decent stretch to get low, but if you have wheels that tuck then your going to be able to get lower! So its basically a combination of the wheel dimensions, offset, tyre size and arches! But most people run the rears a little higher than the front to give a little rake which always looks mad!!
I'm not a huge fan of little wheels on 6n's dont think they fill the arches properly...there are some examples that look very tidy, but bigger wheels look nicer imo.
can some ome apt in the art of le photoshop shove some of these on a decent polo (6n though)...
http://www.imagewheels.co.uk/wheels/small%20cast/lambo.jpg
ta
