15" Alloys On G40 And Drum Issue ?
i have got another g40 and it came with a set of 15" avanti alloy wheels i once owned on my polo gt mk3
i had no spacing on the gt and only had a little scrubbing on arch when cars was full etc plus the suspension was no good and lowered 40mm
I am having the opposite problem on the g40 it is rubbing both sides on the shocks and the hub sticks way out form the centre of wheel much more than front
i am wondering as i dont think my axle is bent could the drums be off a different polo or something it just doenst seem right at all on both sides i spaced out a bit but its still bad
cheers
Do you know the offset of the wheels?
I've got G60 steels on mine and dont have any issues with them rubbing on the shocks but they will catch the arches if i hit a big bump at speed!
the car is in my lock up but my thing is i didnt have this problem with polo gt and same wheels i did have the usual rubbing on arches over big bumps like you though kust confused me a bit
they could have been fitted with 200mm drums off a passat or later golf models, these effectively give you a wider track as well, a way of spacing the rear slightly without the need for stub axle spacers or regular wheel spacers.
are yopu running fatter tyres?
nope they have the same tyres i sold them with and the gt was running standard gt drums cause i remember replacing the brakes in them when i had it i think the problem is the drums on the g40 does anyone know if mk3 drums are any different from a g40 drums ? i know i can space them and get longer wheel nuts but just want to be sure my axle is ok i will be replacing suspension etc and all of this as soon as i gather some dough cheers
