Stopping A Mk2 Polo Sunroof Leaking
On my MK2 polo the sunroof has decided to leak really bad (inch or so of water in the rear footwells) does anyone know a good way to stop it as i am trying to sell the car and it doesent look very good if its full of water :smirk:
hope this is the right section !
Edited by joestanton4
  • Views 5k
My first breadvan leaked like a sieve, check the drain holes are clear with a stiff bit of wire first. the rubbers can be replaced but i put a line of sikaflex round and sealed it up that way, it works if you dont want the use of the sunroof again. i also stripped out the carpets to dry and punched a discreet hole in the floor to drain the water. nothing worse than a mobile bath.
I have a ford sunroof which doesn't have drain holes which has leaked on occasion when ice has got in there and then thawed or if there's dirt and pine needles trapped in there.
I've just bought some Autoglym rubber care conditioning stuff which I believe is good to prevent perishing. Other than that something like vaseline might help seal it or some folk have bodged it with clear bathroom sealant but that means the roof won't open.
I would exam it and try and determine exactly where the leak is. Also check the membranes on your doors which can leak into the carpet without you even noticing it. Can be infuriating with the wind blowing and creating a completely leak all together!
Is it a metal slider or a pop up glass one?
It is a pop up glass one
The pop up glass ones are aftermarket or dealer fit. There's two places they can leak, between rubber and glass, and between rubber and metal roof.
Rubber and glass basically means you either need a new seal, or to get the silicon out and stick it shut. Or get a new sunroof.
Rubber and roof basically means the sunroof wasn't fitted right in the first place, or the roof has corroded round the hole since. Generally speaking, the best bet then is to buy a slightly bigger sunroof and replace it (taking care to cut the hole right, and rustproof the edge.
I have the same problem with mine at the moment. Tried to fix it on Sunday. Problem is a few months ago, I couldn't get the glass back in having removed it. Took a screwdriver and a lot of effort. Now I can't open it or pop the glass out. Whole systems buggered. The joy of old cars... Might have to smash the glass and then replace the whole sunoof system. :cry: Hope not. Let me know how you get on.
