Saggy Bumper
That's the best way to describe it really, it droops down, tilting forward.
Any ideas on how to fix this, it is all bolted on tight, it's only the plastic which i can move up ad down, but sits in a slouch position.
I ca take pictures if needed.
  • Views 646
The inside metal box section will either of had a shunt or it has rusted enough for the plastic outer to become loose.
Take the bumper off and see how well the plastic outer is popped onto the metal box section, Also the brackets have adjustment too which might of worked there way loose (or bent)
I took the metal sections out of my bumpers and hammerited and cavity waxed them. They are a night mare to get off (especially in cold weather) but you should see how a hell of a rusty the metal can get.
If it's looking like a nightmare then get down to the scrappy or use the wanted section and get another one.
