Were Can I Get A Cat Bypass Pipe
I'm after a cat bypass pipe as my cat is shot so ill get a bypass for the time beening as M.O.T got loads left
Were can i get 1 from
My car is a Polo 6n 1.4 8v
Carl
  • Replies 8
  • Views 1.4k
go to any good exhaust fitters and they will order you a straight through piece of pipe mate. for and 8v it will be az bout £15. needs welding or sleeving in then though.
p.s. been an mot'er makes things a lot easier ha. yesssssssssss
Edited by POLOMODIFIEDBREAKINGFOSALE
Custom made I believe.
As for POLOMODIFIED...whatevers comment.
You DON'T want a straight through piece of pipe as you won't be able to pop a new cat back in, you need the down pipe to be custom made with the connections on either end for the cat.
Try powerflow of pipeworx, or somewhere similar.
load of bolox guna cost a fortune. weld new piece in. weld cat back in if u want i tbk in simple. leave cat out ill mot it for u. £35 a test. not sayin it wont fail on owt else though but i can forget to do cat test sometimes. bad memory me.
That the same as what my dad says ill do that then mate tar
Lol tar ill rember that lol
Edited by Po*Low*
well its guna be cheaper and same job at end of day init mate. just an idea though
Yerr
Thanks matee
To be honest I much rather just pop the cat back in 10 minutes or so before the M.O.T than to have to take out the new pipe, weld the cat back in again etc etc
Personal opinion.
Where do you do MOTs mate might have you do mine lol, i like people with bad memories haha
