Head Unit Loses Memory
Hi, i finally got my first car and its an ace polo 6N 1.4. I just bought a new sony head unit for it, but everytime i get back in my car, it has lost all of the equaliser custom settings and all of the radio pre-sets. It seems to go back to its factory settings.
Any ideas? could it be my car or maybe the head unit?
thanks in advance.
  • Replies 18
  • Views 2.3k
i had this problem. if you swap the two wires in the back around ie the yellow goes into the red and the red goes into the yellow. that should sought the problem.
your 12v supply and earth are the wrong way.....
or it could be the 12v permanent supply and 12v ignition supply that have been connected he wrong way round.
get a multi meter out and check which is which, and refer to the wiring diagram of the head unit.
sorted
thanks in advance.
as spookey says ... swop the RED and YELLOW over then your sorted...
aye, swap red and yellow, sounds dodgy but its quite right!!
Thanks guys, i did that this morning and now my head unit works perfect. :-D
I had the same problem ill give it a shot tomorro like :)
hey I've got the same problem, tryed to swap red/yellow but ... there isnt one lol
the only power wires i have are
thick brown
brown/red
bluegrey
white- also attached to ariel
can anyone help?
thick brown
brown/red
bluegrey
can anyone help?
find the main live feed from the battery u willl need a miulti tester and then look as stereo and find the memory wire put the live to the memory wire thats what i done
swaped my red and yellow, it worked, no more messin about finding stations now :D
done this on mine too :-D be careful tho, if i dont remove the face plate then it continues to draw power and drain the battery
novice here, i have the same problem and have looked at the radio and located the yellow + red wires but i dont know how to swap em over n dont wanna break em
how do you remove the wire from the block its attached to?
thanks
Lowell
we have the technology....
ok I think this is my problem too I need to swap the red and yellow around...
thing is how do you actually get the original head unit out from the cubby hole frame without messin up your dash?????
cheers in advance
cheers in advance
you need the original keys for the head unit ideally, otherwise you can either buy keys off the internet or other methods include using coat hangers or brute force!
basically anything which will fit down the sides of the unit and be able to pull it out again
cheers in advance
sorted it now cheers
there is soo many of these behind my head unit! but somehow organised.
That doesnt sound right, it should turn off when you remove the key :/
switched the red and yellow wires today as I was having this very problem....and now its all sorted! :D
