1.4 16v Anti Roll Bars....
hi peeps ime sat about 100mmish on the front n the anti roll bar is actually touching the chassis jus wunderd if any 1 on here new a way round this???
upgraded anti roll bar.....but do they sit lower?
cut a notch in the chassis n weld back up inside the notch???
if any 1 has or has had this problem and solved it could they let me know plz...cheers heres a few pics
Edited by hudds dubs polo
  • Replies 21
  • Views 2.3k
Remove it. Done it on mine.
As the car is lower of stiffer suspension you'll have less body roll anyway
maybe thats whats the well annoying knocking is from mine...
thought about this but wasnt sure if it would handle sh*t???
could possibly be m8 mine only knocks bad when hitting patched up roads??which are everywer wer i live?lol
Aslong as your front wheel alignment is spot on you should be ok.
okey mate all go get it checked at the weekend or should i wait till the anti rool bar is of?
Remove it?! Madness!
Are you being sarcastic or not? It's the simplest, cheapest, and by far the most effective method.
thanks guys. off it comes at the week end.are they easy to remove or are they a bitch???????/
The easiest way is to split the exhaust to get it out.
okey m8 thanks for the info :thumbsup:
mines same,,been sat on the arb since i lowered it.knocks like a idiot on rough roads.
prob fail a mot if you remove it
just let it rattle i ran my old polo for a year with it at 100mm and doing the same on my current one
Edited by Sam_R
How will it fail an MOT without a front anti roll bar?
On a mk4 the lesser models don't even have one.
Don't got spouting rubbish when you don't know what you're talking about.
a good mot place with be able to tell if its ment to have on of not from the chassy number
You're neglecting the fact it doesn't actually matter. It's not part of the MOT. I have run at least 3 mk1/mk2 escorts without front anti roll bars, people running subframes on mk3 polos remove the arb. It's not part of the MOT if its not there hence the lesser models still pass without one.
And it's chassis btw.
if the car comes with one its ment to have one
I've only ever seen them on the valvers and 1.6s
sorry sam R but gofasterpinch is right
like a spare wheel and rear wiper, if you have one in the car it is checked as part of the mot, if its not there, there is nothing to be checked!!
and I'm sure that 16v or not they all have them as standard!!
Not all mk4s have a front ARB at all. I conversed this with tobyK a while back. 16v, diesel and 1.6L only (i think). 18mm diesel and 1.6L, 16v 20mm or german mk4 GTI 22mm.
This is what happened to my polo as well and am only sitting at 80mm :lol: all i done is fit rubber seals around them and its been fine ever since no bad rattles nothing and it goes through a MOT fine
okey guys thanks for the advice.all I've done to stop the banging is cut and old tyre up and bond it to the arb.hey presto it doesnt bang and has stoped wearing my chassis away.and u guys are right jus got under the polo ime breaking which is a 1ltr chassis and it hasnt got a arb on it, neither has my mates 1.4 8v se??dnt no y this is tho?????
