Just Quick Urgent Question
I'm just in the middle of first coat of primer of my badges front and rear. il do three coats but do i need to sand it down after I've primed it? if some one could tell me that would be great :D
  • Views 742
yes,it will give a good key for the next coat
so I've sanded both down a min go sprayed first coat of primer but a little bit has run :( then il sand down after three then spray my three coats of surprise paint :D then laquer it? or sand down againn after paint and laquer?
Yeah sand down where it has run, give it a couple more coats of primer (sanding between if you want). And as for painting, you may want to wet-sand it inbetween coats, but DON'T wet-sand the last coat or laquer haha.
cool cheers for that il sand it down after last coat then paint it thenlaquer with nosanding inbeetween
