Wont Start
hi wondering if anyone can help my polo 6n wont start i know its not the bat as i have tested that when i start the key it will not turn over fully and all the power drains from the batt i gt a new batt and this still happens thanks liam
  • Replies 9
  • Views 1.6k
Will it run if its towed or pushed?
Probably worth cleaning up all the earth straps & battery leads
Might turn out to be a faulty starter or switch
Would try the others first
check the ovious fuel spark compression , if u got all 3 then think about timming , I'm geusin coil pack tho its a common problem
yeah it wont start even if i jump or bump start it
anyone else gt any ideas
Are you getting a spark?
It could be the dizzy thats gone or as said the coil pack
Mine is the same i charged the battery and it turns over but wont act fire up :S
Its had new leads, plugs, and dizzie cap + arm and fuel filter...
Edited by joshy_polo
Are your leads back on in the right order?
Yup, it used to run fine then start not starting, then wont start at all...?
Is it giving a good spark then?
If not then it could be the coil pack
