My Boot
it took me about a week to unlock my boot!
finally got it unlocked and now it wont lock!!!
i dunno what the problem is but the key wont turn..
??? anyone got any ideas on how i can get it locked again?
sam
  • Views 1k
my mk3 had this
you need a technique to do it
put some oil init, then wiggle the key when you lock n unlock it
also depres the lock slightly as you do it
with mine i had to push lock in slightly and turn the key the opposite way slightly to make it unlock
same with locking
The above didn't work for me or anything else on my G40, so I've just taken that thing off (whatever you call it haha) and de locked it :lol:
Edit: That be why the boot was open when I picked it up and I didn't attempt to lock it till I got home
Lesson learned
Edited by D16RRT
spray some WD40 in it, stick key in and wiggle it as described above by neil.
My boot lock did it the other day and it just needed re-lubricating.
ah really?
ill try that then!
thanks guys :)
and girls of corse ;)
hi guys,this is my first post so go easy on me :?
my boot lock was doing the exact same thing up until tonight where it's decided to start working again but the handle won't open the latch ,i think there is something missing on the inside,if i can fire a picture up in the morning can some of your guys compare it to whats in your boot lids to see what bit's i'm missing.
cheers
the luckless mk4 lad
Yeah mine was getting a little tough aswell as my drivers door, WD40 loosened it up loads.
