Really Quick Guys, Please
Can you use wet 1200 wet sand paper between coats of clear coat or not??
cheers
  • Views 720
yes you can, but you'd have to prep/clean it before spraying.
Why do you need to? Dirt in the lacquer? as long as the lacquer has dried properly then you can treat it as described before spraying again.
HTH
could sand inbetween coats but no real need?
do a dryish coat then 2 wet coats and let it dry out for at least a week, give it a 1200,1500,2000 going over then another 3 coats of clear. wetsand then buff an voila!
