00 Reg Polo Central Locking Problem
Hi I dont know if this is the correct forum for this but here goes, My daughter bought a 00 Polo during the week the central locking worked fine but for some reason tonight only the drivers door locks and the 3 other doors wont lock through turning the key in the drivers door we have to lock the passengers door on it's own and the 2 rear doors wont lock at all. Help please.
  • Views 842
Check the fuses (specifically the ones to do with central locking; when you remove the cover to look at the fuse board, there's a card on the back of it outlining what each fuse does; look for the ones with a key)
Also, check in the rubber flexi-boot that connects the drivers door to the car, chances are the black and white cable inside maybe broken as its pretty much the same problem I had with mine
Check the lock mechanism too, as this is the master control for switching all the other locks on or off
Thanks guy, I will check the out your responses tomorrow weather permitting and let you know how I get on. Hopefully it's a small problem
