Fitting A Momo Team Wheel
Hi guys, I'm going to be fitting a momo team wheel tomorow morning. I have just assembled the wheel in my room to familiarise myself with how it goes together.
I can guarantee however, that I will get stuck tomorow morning as the instructions are vague and are not for this particular wheel, they are simply universal momo instructions.
I am struggling to work out where these 4 components go, and if all 4 are neccessary.
I believe 2 may be for the horn and one for the airbag resistor? Do I use these or the existing wiring from the old original MK5 wheel? Do I remove all the wiring that is attatched to the MK5 wheel and replace with this new wiring?
Please see pics below
Any help much appreciated,
I have this pic of the rear of the horn push, but I don't know which of the two wires would go to each connector, and where they would go from there on?
Edited by indy231
  • Views 894
Not all the wiring will be needed...
But try using the original wires on it and see if that works...
If it doesnt work play about with it, nothing bad should happen
If all else fails...
Buy a switch and wire your horn to that and pull your airbag light from your dash :lol:
