Bumper Crack
I have a question a mate of mine reversed into a double kerb in his mk5 polo and it took out a tennis bal size chunk out of the bumper he still has the chunk that came out and asked me to fix it for him, whats the best way to handle this the best way possible
Sam
  • Views 1k
Would this work ok ?
Super Plastic Glue
If its a plastic chunk it depends what type of plastic it is as to how well it will glue. If you can access the rear of the bumper, you could put the piece back in & "weld" it back in from the rear with an electric soldering iron
As far as i know its just the standard bumper , would a soldering iron be the only thing i need ? would like to make some money outer this :lol:
Edited by samchatt
Unless you know what type of plastic it is you might find it hard to get a glue to do a permanent job. You may also be able to stick it in from the rear using body filler or even the fibre glass filler. Depends on access.
I've had very hit & miss results using plastic glues. Araldite epoxy resin is good but takes hours to set
If its the sort of plastic that melts when heated then I've had good results with a soldering iron
id say get the bumper off and obtain the piece that came out, make a slight v on all the edges so there is a slight channel when there together, hot soldering iron them back together and then when its cooled down, rough up the back with some 40 grit paper and lay on some resin and matting to add some strength and then plastic filler and prep the outside for paint :)
