Removal Off 6n Rear "vw" Badge
I want to remove the rear vw badge so that i can spray it black, but whats the best way to take it off and whats the best stuff to re stick it?
  • Views 815
just prize it off slowly, it should come of reasonably easily! After you've painted it get some super glue and fix it back onto the back plate!!
It's easy to peel off but I would personally heat it up first (not too much) to soften the glue just incase you peel some of the laquer off along with the badge. And if you do it that way it should go back on and stick properly again :thumbsup:
