What's A More Accurate Speedo?
trying to work out what is more accurate as there is a 8mph difference between the two, I've got a GT lowered 80/60 on 13" wellers running 175/50/13's.
any one else running an incorrect speedo?
  • Replies 17
  • Views 1.5k
satnav is the more accurate one, 8mph sounds about right if your doing motorway speeds
id also like to know whats more accurate as my satnav is 4mph under my actual speedo reading .....
cheers, i wondered if it was, feels odd though going through speed cameras when the speedo is reading over the limit!
i think there was a thread containing a link to how speedos are affected when changing the wheels diameter and tyre profile, it calculated it accurately,
At a constant speed sat nav is more accurate, it's not so accurate for accelerating/decelerating though as there's a slight delay. Mattyc I expect your speedo is under-reading because you've got bigger wheels. Each time your wheel rotates you're covering more ground than on smaller stock wheels.
On my 6N there is maximum 1mph difference between my sat nav and speedo , but then again I'm on standard wheels
HERE
GPS is always gonna be more accurate, hence why timing gear uses it.
Mines about 10mph ish out at speeds of 70+
my gt is 10-14% out. it gets worse the higher the speed.
gps is more accurate
mines out by about 4-5mph at 70
there tyre calculators tht u can go on and put in you are original size wheel and tyre and what you have now and it will tell you how out it is
when your car is well off the clocks its actually doin 115 on gps lol
back in the day there was some legislation on this for safety reason, don't think it still stands, hence modern cars speedos' are more accurate! fords of the 70's/80's speedo was 10% out so...
55 speedo = 50mph road
88 speedo = 80mph road
so on and so forth!
yer iv got wellers on my polo and my clock said i was doing 115 in a 1.3 coupe :D il just pretend they're right...
I've heard of some folk that car speedo's are set 4 mph under your actual speed. Sounds about right to me after comparing sat nav to speedo.
Must be to keep you on the safe side of the speed camera's or summet!!
If you really want to feel good about your top speed, do what the bloke who had my mk2 coupe did and put a gearbox on with the wrong speedo drive mine would happily go straight past the speed clock and start pointing to the time clock. :badgrin:
Sat navs are not that accurate up hills because the sat only recognises lateral movement and not depth (mine anyway). So this means if you are going up a hill, and going at the same speed, it will think you are going slower as you are not moving across as fast. Dont know if anyone understands but my physics lecturer told me lol
