Corrado Rear Bench In 6n
Has anyone done it before? anyone got any pic's? is it hard?
Thanks,
Ash
  • Replies 9
  • Views 1.2k
shouldnt be much harder than fitting a mk3 golf rear in, guess you would need to mod the wires and use your polo wires to fix it into the car and maybe secure the back rest in somehow
So if I was to strip the foam off the polo back frame and then stick on the corrado foam that should work? is it the same size as the mk3 then? not the mk2?
Thanks,
Ash
pretty sure it would, have a scout around on edition buddy as there may be more answers on there.
good luck with it as rado rears are sweet
I've been trying to get onto ed for a week, just keep getting wrong password :( even reset it 3 times.. might have to join again or something
yep i get that and it also signs you out and stuff :(
that's pant's... maybe we should start up Ed39 :lol:
haha :) yeah maybe buddy
i have enough fun running www.crazydubs.co.uk go over there and have a look :)
i know its rather narrow the bench and in my mates mk2 golf he has had to have side bolsters made to slot in between the seat edge and the door cards when he had MJ trim them
Rado bench fits a Mk2 golf nearly directly only needs the top catches modding, I've done it.
It won't fit a 6n without a lot of hassle as the fixing method is totally different.
