Problem With New Steering Wheel
Hi guys, still having problems with my MOMO team wheel.
The casing which the airbag coils go into is sitting flush to the nearest mm to the boss, and the plate with the copper ring and 4 connectors behind it is sitting flush to the plastic casing which had the airbag coils in. The plastic case and the plate behind with the copper ring on it spin freely and are held in place when the boss is tightened.
I tighten the boss, put the steering wheel back on, and the horn works fine with the horn push but as I turn the wheel there is one part of the copper ring or something else which causes the horn to go off, but only at one specific point when the wheel is turned.
I really don't have a clue about this, I've tried everything I can think of. Can anyone please shed any light on this?
This is the plate with the copper ring on it which i put back on the steering column, not sure if it matters which way round it goes aslong as the copper ring is touching,
This is the metal pin which i have not moved which is inside the plastic airbag coil casing which seems to stop the casing from shutting properly but i can't move it out of the way as it is fed through the casing and I'm sure this hasn't been moved from how it was originally
and finally this is a pic of how the boss and everything fits together, the boss is bent in the pic but it is straight now
can anyone help me out please?
  • Views 849
try taping over the other screw !!
I've got the same problem mate.
you need to bend the copper contact on the steering column so that there is minimal contact. trial an error really.
it worked on my mk3, but having swapped the boss an wheel on to a mk4 we had the same problem which I've not been able to sort. ended up taping over the contact on the steering column as thats the only way could use the wheel without the horn going off. obviously dont have use of a horn now though which isnt ideal.
if you sort it let me know. but id say the problem is to do with the copper bit contacting the boss........ have a mess an see if it improves.
Sorted it. Problem is that the boss and everything wasn't sitting totally flush causing the copper rod to contact when the wheel was turned. Works fine now. Still shit scared it could start happening at any moment though.
well if the horn is in the same place as a 6N then its just behind the bumper on the passenger side. would be easier to just reach under and disconnect it!!
Lol I just said I sorted it
yeh i ment if it suddenly starts going off when your out and about.
