Steering Wheel?
Cheers, it was already broke when i bought the car :( whats the best way of getting around this? Getting it welded, and I've tried removing the spline with a puller but the puller doesnt grip the edge enough and just slips off??
steering lock is part of the ignition barrel and the like as far as i remember
just get a mate to hold the wheel and then undo the center nut unless you have arms like a baboon to do it yourself.
shouldn't need to remove the spline as that boss will fit straight on
Sorry its not the steering lock, theres a black tube that is bolted and when the steering lock is on its stupossed to stop it moving any further however mine does as the weld has been snapped?
um right well hit it with a welder then and that will be it fixed :)
