Paint Pulled Off Front Bumper.
Cut a long story short, some L-plates were stuck onto my car and when the front one was removed it pulled some paint off the bumper, arrghh! :crybaby:
Anyone have any tips/experience at fixing this? Will be most appreciated! :-)
Here's a quick photo I took:
  • Views 1.3k
appears to just be the laquer? touch it in, flat it back, polish it up and it should mask it a bit :)
My only problem is that I'm a complete novice at this, never done anything like it before!
halfords for your supplys
Can of clear laquer
some white spirit
1500,2000 wet and dry paper and polish
masking tape
Wash the area you want to spray with fairy liquid to remove some of the waxes and contaminates in the paint.
Take the 1500 wet and dry paper, tear a sheet in half and fold into 3 parts, bucket of warm water and a dab of fairy, put the paper in the water and wiggle it about (the girls love it) then take it out and gently rub at the edges of the area until they feel/look smooth.
Mask the headlights and grill and any other parts you don't want over spray on.
Take the can of clear laquer and drop it into the warm bucket of water (makes the pressure higher in the can and the paint come out better) then take out after a couple of minutes and shake for whatever time it says and some more.
Spray the area from about 15cm away (practice first on something else) do 1 light coat and let it tack off for a couple of minutes then follow it with 2 wet coats of laquer.
Leave it to dry for 24 hours then take the 2000 grit wet and dry paper, bucket of water and fairy and give it a jiggle, rub the sprayed area smooth to remove any orange peel and then polish the area.
Job done, estimated time 27 hr's (allowing 24hr drying time)
difficulty = Monkey level
Lots of detail for you fella but dont be scared
Dry off the area and surrounding,
Can of clear laquer
some white spirit
masking tape
Mate...thank you very much, I'll go Halfords tomorrow and get the bits. All I need is a nice, dry 24 hour period and I'm sorted. Thanks again buddy, I really appreciate it! :-D
