Condensation On Inside Of Windscreen
I have a mark 2 Polo with a factory fitted sunroof. For the last few weeks, the inside of the windscreen has been soaking wet with condensation.
I also have a REALLY rusty front wing - the entire front arch to be exact.
What are the common 'leaking' points on a mk2? Where do I start looking basically and how will I know when I've found it? ;)
Also, does anybody know a good, i.e cheap, bodyshop in the berkshire area? I have a new front wing (the last VW offside front wing in the UK I believe) so don't really want to fit it myself in case I cock it up. Plus it needs a square cutting out for the indicator.
I've been quoted £235 to fit and spray, which is almost as much as the car's worth... :unibrow: Is that a good deal as that was quoted to me as a 'cash in hand' price or do you think I can get it cheaper? Anyway, condensation first, wing second.
Chars!
  • Views 1.7k
try the bodyshop at a1 car spares in wokingham, they're fairly decent and cheap. just have a mooch around and inspect their work and make your own mind up.
body work under the battery rots and leaks.
Have a scout around for wet carpet/upholstry
Door seals & the plastic behind the door cards are 2 favourite leakys
Are the sunroof drain holes clear
open the sunroof and look towards the front and rear and you will see the drain tubes, grab some wire and slide it down these as they get blocked with debris and this may help, other leaky points worth checking are rear light seals, main door seals and generally wet inners
