Is It Normal To Get Slight Knocking Sounds When Using An Aftermarket Steering Wheel?
I just fitted my momo team wheel yesterday but when I'm turning there is sometimes a knocking sound coming from the boss area. The boss doesn't move when I grab it and try to move it about, but sometimes when turning it makes a slight movement like a pop up and down really quickly about a millimetre. I was just wondering if this is normal and can be expected when using an aftermarket wheel in the same way that it is normal to get knocking noises from the top mounts when riding on coilovers.
I just don't like the knocking as I feel it happen and my confidence is really low to thrash the car about because I'm scared of the steering wheel falling off or something stupid like that lol.
Shall I just take it to a garage and let them check it over for secureness etc?
Any help will be much appreciated.
  • Views 702
take it to a garage to be checked over just in case.
how low have you got the steering wheel (as in the adjuster bit on the side of the colom)? on my old car if i had it too far down it made a bit of a knock, try putting the steering wheel right up and see if it goes away.
I have it kinda adjusted into the middle. I didn't tighten the nut in the middle that tightly at all as I was scared of having an old problem where my horn doesn't stop beeping if the boss was tightened too much.
I am going to take it to a garage within the next couple of days though and get it checked over properly :)
