Polo 6n2 Front End On A 6n
I've just brought another 6n to do as a project. all the front panels are missing (bonnet, wings, and bumper), so i was thinkin i may aswell put a 6n2 front end on to make it a bit diffrent. i can remember someone saying that you either need gti wings or standard wings but i can remember. also what other parts do i need other than the bonnet, bumper and lights????
  • Replies 16
  • Views 5.9k
maybe lower section?
anyone know?
mk1poloblade is currently on with this conversion,,,as far as I'm aware the bits pretty much just unbolt and new ones bolt on,,the shelss are essentially the same so it should need much fettling to get it all on,,theres a lad on here with it done and it looks smart..i thought about it yonks ago but prefer the look of the 6n really,,go for it though dude.
do you know the lads username who has done it as i will pm him. need to find out pretty soon as I'm gonna order the parts 2moro. either the 6n or 6n2 front.
iirc Ash on here has something like that... his might be custom tho :?
yeh his is a custom job, where the 6n2 bumper has been made to fit on a 6n front end.
Would it not then look exactly the same as a 6n2?
the front will but the back wont. i wouldnt normally go out my way to change the front end but seeing as this one hasnt got any panels on the front at the anyway (how i brought it) i thought well why not....
polo82 or something had a 6n2 front bumper on his 6n, chopped a valver bumper in half and used the 6n2 bottom iirc
i wouldnt mind doing that as ash's looks well good but I'm just looking to fit standard panels..
I think you might run into issues with the headlights unless you're also replacing the front panel (the big plastic thing that the radiator sits in) as this also houses the headlights and grill - and I know that 6n2 lights are not just a straight swap for 6n ones.
thanks for that. i was wondering about that part tbh. would the 6n radiator fit into the 6n2 front panel though or would i need to get a 6n2 rad aswell
you need;
front panel
bonnet
wings
inner arches
headlights
indicators
bumper
crash bar
also the 'plates' - the square bit on the front of the chassis leg are different and the tow eye position is different.
for ease of application i'd go to a scrappy and drill out the spots welds on the 'plates' from a 6n2 and weld them onto the 6n chassis legs.
the little brackets above the indicator where the front panel bolts on at the top will also need to be borrowed from the 6n2 body.
6n rad fits 6n2 front panel and the fan also bolts across 6n - 6n2 panel.
think thats it.
you need;
front panel
bonnet
wings
inner arches
headlights
indicators
bumper
crash bar
think thats it.
thanks alot mate.. :-D
i did have some pics at home of the differences, if i haven't deleted them i'll post them up.
It has been done before.
Sliver 6n diesel PVW was at ED38 two years ago
